12590 Discussions
No licenses 'RSTM_Pool_Pro' available
I am using the FVP_VE_Cortex-A9x4.exesimulation tool with the latest DS-5, but when tried to launch this, I got some strange error ! how to fix this?
I just double clink this file and it pop up for some application window. by the way. did you have your license installed ?
this is strange, how did the window looks like?
I have a reason to believe either your license expired, or evaluation copy which is not entitle to use this feature
http://ds.arm.com/altera/
What is the license type that you are using? please go to check it in the Help\Arm license manager.
my god.... after i reconfigured the network proxy and try to grab another evaluation ultimate license, it works already...
you may need to confirm with your FAE for the license that you are using . some feature is bounded with certain license family!
wonder why the license got so much restriction anyway?
hi Light, cool down. actually when you read the link that i paste you earlier related with the license coverage, you can clearly see, actually this is not truly a restriction.
