Nonvolatile Memory
Hi all. How is the entry value of the variable to the nonvolatile memory, and then to count:confused:
Flash loader EPCS16.
Hard to guess what you are asking about. Please try to rephrase and elaborate the question.
For example on Arduino the entry T1=EEPROM.read(4) means the reading from the nonvolatile memory of the value of the variable T1. How is this implemented in nios?
You need to use the EPCS serial flash controller core. See chapter 5 of the embedded ip user guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_embedded_ip.pdf). You need to decide where in the EPCS you want to put your data and there are functions to read and write pages.
