12602 Discussions
Not able to factory restore my board
Hello There,
I am not able to restore factory setting on my board , i am following the instruction given in nios dev. board ref. manual , i am not able to restore my board on factory setting.
the steps i am following.
1. Open the Nios ESDK Shell
2. Chnage the directory to c:/altera/quartus50/example/factory_recovery/nios_cyclone_1c20
3. type the command "./restore_my_flash"
please see that attached output of my shell.
and help me out how do i overcome from this issue
i have also attached my Environment Variable Setting also for your reference
kaushal
Quartus 5.0 ! It is a April 1st joke ;-) ?
Hi, it seems your Quartus installation has been corrupted.
You have Quartus 5.0 and Quartus 9.1SP2.
You "SOPC_BUILDER...." environment may be corrupted : the "+" is suspicious, the paths should be separated by a ";"
Try to redownload the Factory Flash through Nios II IDE.
