i used the tarball nios2-linux-20090730.tar
and i wanted to used the openssl for net-snmp v3 the make menuconfig setting is : uClinux Distribution Configuration Network Applications ---> [*] openssl some errors when make : [ ! -d "openssl" ] || ( touch openssl/.sgbuilt_user && make -C openssl ) || exit $? make[3]: Entering directory `/nios2-linux_snmp/uClinux-dist/user/openssl' make -C /nios2-linux_snmp/uClinux-dist/lib/libssl all_user make[4]: Entering directory `/nios2-linux_snmp/uClinux-dist/lib/libssl' make[4]: *** No rule to make target `all_user'. Stop. make[4]: Leaving directory `/nios2-linux_snmp/uClinux-dist/lib/libssl' make[3]: *** [all] Error 2 make[3]: Leaving directory `/nios2-linux_snmp/uClinux-dist/user/openssl' make[2]: *** [openssl] Error 2 make[2]: Leaving directory `/nios2-linux_snmp/uClinux-dist/user' make[1]: *** [all] Error 2 make[1]: Leaving directory `/nios2-linux_snmp/uClinux-dist/user' make: *** [subdirs] Error 1 [root@localhost uClinux-dist]# What is wrong ? and what should I do ? thanks for you help! arensLink Copied
Hi Arens,
I had the same problem here. Did you solve this problem eventually? How? Best.
