I use nios2-linux-20100621.tar without MMU in 3C40 board.
I already update the kernel, insert 2G, 4G or less U disk, this is ok. But insert 8G U disk, it show "Too big for this kernel. Use a kernel compiled with support for large block devices.". I download uClinux-dist-20111111.tar.bz2 to transplante, but i failed.Link Copied
Well, seems like You need to recompile the kernel with according parameter.
