Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
PIO for Compact Flash card
I am working with Nios II processor and I would like to know which PIO and which libraries can I select to send data to the compact flash card. In the manuals this information is not very clear.
Could you help me?
Thank you very much.
Ana.
Highlighted
Re: PIO for Compact Flash card
I think you need to use the documents that came with the dev kit you have and map those pins to the CF part of SOPC builder. Then you need to build on top of the provided low level drivers to interface to a card, or I hear there are more high level functions written and avalaible somewhere on this site - which I am currently searching for.
