While compiling uClinux, a command is required to send the hardware features and corresponding addresses i.e. "make vendor_hwselect SYSPTF='path to ptf file' ". However PTF file is generated by SOPC. Newer version of SOPC, Qsys does not generate a PTF file. To compile the uClinux for a environment created by Qsys, What can be used? Thanks.Link Copied
--- Quote Start --- Hello, While compiling uClinux, a command is required to send the hardware features and corresponding addresses i.e. "make vendor_hwselect SYSPTF='path to ptf file' ". However PTF file is generated by SOPC. Newer version of SOPC, Qsys does not generate a PTF file. To compile the uClinux for a environment created by Qsys, What can be used? Thanks. --- Quote End --- PTFs are no longer created, and the uCLinux build no longer requires you to run the hwselect command. Instead, you should create a device tree from the sopcinfo file using sopc2dts. --dalon
--- Quote Start --- PTFs are no longer created, and the uCLinux build no longer requires you to run the hwselect command. Instead, you should create a device tree from the sopcinfo file using sopc2dts. --dalon --- Quote End --- Thanks a lot. Can you provide me a fresh source of uClinux that does not require the hwselect and can run on Nios II?
Install
http://www.alterawiki.com/wiki/linux_desktop_install http://www.alterawiki.com/wiki/linux_quick_start http://www.alterawiki.com/wiki/sopc2dts goodluck. also try using the mailing list http://sopc.et.ntust.edu.tw/cgi-bin/mailman/listinfo/nios2-dev --dalon- Mark as New
Thanks a lot dwesterg. I will start to deal with uClinux again.
