Could you specify the parameters of SYG_FLASH_DRIVER macro?
I have got a 128MB flashlike device with 130 blocks of 0x10000 bytes size and 4 ones of 0x4000 bytes. So, I made such an array: static const cyg_flash_block_info_t p8p_block_info[2] = { {(size_t)0x4000, (cyg_uint32)4 }, {(size_t)0x10000, (cyg_uint32)130 } };and then wrote the macro: cyg_flash_driver( p8p_drv_handle, &p8p_func_handle, 0, /* flags */ cygmem_region_flash, /* flash first address */ cygmem_region_flash + p8p_region_size - 1, /* flash last address */ 2, /* number of items in p8p_block_info*/ p8p_block_info, &p8p_priv /* pointer to priv handle */ } ;
As a result, eCos dies. Can you see the error(s) ?
