12604 Discussions
Pause DMA if the receiver peripheral cannot accept data for a while
I could run the DMA core to read data from the onchip memory and send to one peripheral. Is there a way to pause the DMA core because the peripheral cannot accept new data for a while?
You try try asserting the waitrequest signal from your peripheral so that it will backpressure the DMA.
OK.
The avalon slave interface has a lot of signals like write data, write, readdata, clk ,reset,.... and so on.
Is there a good tutorial other than the official documents that explain the avalon slave interface in detail by examples?
OK mikedsouze, this solution worked. Thanks
