Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Performance counter report
Hey
I am running performance counter on my C code
My problem is that the report only show the result for section 1 !! (even if I change sections order it only show the first)
It should show 4 sections !
What could be the problem ?!
thnx
perf_print_formatted_report((void *)PERFORMANCE_COUNTER_BASE,
ALT_CPU_FREQ,4,
"section_1",
"section_2",
"section_3",
"section_4");
--Performance Counter Report--
Total Time: 3.35524 seconds (335524437 clock-cycles)
| Section | % | Time (sec)| Time (clocks)|Occurrences|
|section_1 | 0.27| 0.00905| 905319| 1|
|section_2 | 0| 0.00000| 0| 0|
|section_3 | 0| 0.00000| 0| 0|
|section_4 | 0| 0.00000| 0| 10175|
It's hard to know without seeing more code, but perhaps you are forgetting to change the second parameter of the PERF_BEGIN/PERF_END calls for the different sections?
... // Section 1 PERF_BEGIN(PERFORMANCE_COUNTER_BASE, 1); foo(); PERF_END(PERFORMANCE_COUNTER_BASE, 1); // Section 2 PERF_BEGIN(PERFORMANCE_COUNTER_BASE, 2); bar(); PERF_END(PERFORMANCE_COUNTER_BASE, 2); ...
--- Quote Start ---
--- Quote End ---
thnx I solved it
