I'm trying to add an DDR controller to my design in the Cyclone 3 Nios2 Embedded Evaluation Kit. I have checked some examples and all examples export the interfaces "external connection" and "memory" from the controller. In the NEEK documentation I found the PINs to assign to the "memory" interface with the pin planner but I cannot find where I must connect the "external connection". These are the pins that I don't know where I must to assign them: external_connection_local_init_done external_connection_local_refresh_ack external_connection_reset_phy_clk_nLink Copied
Finally I found the solution by my self. Simply, in the top level don't export those buses hehe.
