12603 Discussions
Ploblem Occurred Downloading ELF Process failed by QuratusⅡ v.13.1 with DE0 → Cause ?
:confused:Please Could you teach us some hints to make it work. It's a user with little experience.
I use QuratusⅡ v.13.1 web with DE0(board name).
I want to move sdram.;)
In the basic Qsys setting ⇒ NiosⅡ Eclipse ⇒ Run as ⇒ NiosⅡ hardware,
the design is stopped. Here,over a week.:cry:
When lcd is implemented in Qsys, display operation is done .It's moved. but I setting sdram at Qsys . then ,Displayed message box :oops:​what Downloading ELF Process failed .  I read some Q and A this Altera Forum. but I don't get success . can't move Nios Ⅱ e processor with sdram. this project what can't move file URL : https://drive.google.com/open?id=0B4eNVJA-xoSQR1EzRld1SzBQbGs
⇒ I get good news by book. http://shop.cqpub.co.jp/hanbai/books/48/48191.htm
JAN9784789848190 p110~ good. I'll change sample project what this book.
Now Hiroyuki writting.
I get good news.
I was buying a book around 2013 waht http://shop.cqpub.co.jp/hanbai/books/48/48191.htm
JAN9784789848190
P110 ~ just for sdram .
I'll change this sample project with book for need function.
thank you for reading.
Please Could you teach us some hint to make it work. It's a user with little experience.
I use QuratusⅡ v.13.1 web with DE0.
When lcd is implemented in Qsys, display operation is done .It's moved. but I setting sdram at Qsys . then ,Displayed message box ​what Downloading ELF Process failed . It is a user with little experience. project file URL : https://drive.google.com/open?id=0b4...1ezrld1szbqbgs
