12600 Discussions
Pointer access from qsys custom component
Hello
My nios code is running on a DDR
I have also a custom component connected to the DDR
The purpose is to define a pointer register in DDR and to overwrite its value from the custom component through its avalon mm bus
So, if i define a pointer on the c code . lets assume its address will be 0x800.
Which address should be used on the avalon mm bus of the custom component in order to do that ?
Thanks in advance
