Prob niosII
hello,
I have this problem when
i run my code under NiosII
using cable "usb-blaster [usb-0]", device 1, instance 0x00
pausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused
regards
Many things could cause this.... Have you checked that you have:
  1. Programmed the FPGA with the hardware your software is based upon
  2. Checked that clock and reset are properly connected.
Beyond that...this is a _very_ common issue and you'll find lots of other posts with additional suggestions of what to try.
Cheers,
slacker
i try to verifie the that clock and reset are properly connected. but
i don't resolve the problem
have it someone can help me?
regards
Is this a problem related to a new board or to a specific project.
I mean, can you correctly load a different design on this same board?
Are you sure the fpga has been correctly configured before you try loading Nios software?
