hello,
I have this problem when i run my code under NiosII using cable "usb-blaster [usb-0]", device 1, instance 0x00pausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused regards
Many things could cause this.... Have you checked that you have:
- Programmed the FPGA with the hardware your software is based upon
- Checked that clock and reset are properly connected.
i try to verifie the that clock and reset are properly connected. but
i don't resolve the problem have it someone can help me? regards- Mark as New
Is this a problem related to a new board or to a specific project.
I mean, can you correctly load a different design on this same board? Are you sure the fpga has been correctly configured before you try loading Nios software?
Topic Options
