Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Problem building hello_world
Hey anyone
I have this problem.
I have bought a cyclone dev. kit. and used the standard niosII_cyclone_1c20 form the example list in Quartus.
this kan be compiled with no error.
But when i try to build my hello_world in nios this error come(look below)
Anyone knows what I am doing wrong.
Best regards
Imagine
**** Incremental build of configuration Debug for project hello_world_0 ****
make -s all
Creating generated_app.mk...
Can't locate sh_launch.pm in @INC (@INC contains: /cygdrive/c/altera/kits/nios2_51/bin:/cygdrive/c/altera/quartus51/sopc_builder/bin::/cygdrive/c/altera/quartus51/sopc_builder/bin:/cygdrive/c/altera/quartus51/sopc_builder/bin/europa:/cygdrive/c/altera/quartus51/sopc_builder/bin/perl_lib .) at - line 3.
BEGIN failed--compilation aborted at - line 3.
make: *** [C:/altera/kits/nios2_51/examples/verilog/niosII_cyclone_1c20/standard/software/hello_world_0_syslib_0/Debug/system_description/../obj/generated_app.mk-t] Error 2
Build completed
Hmm, in my NIOS 5.1 installation sh_launch.pm exists in the altera\kits\nios2_51\bin directory so the script should find it. Check to see if you have that file. Also check the case, I think it might be case sensitive.
The existing project probably works because it doesn't have to run generated_app.mk. This only happens when your NIOS design changes.
Andrew
Highlighted
The problem is not there anymore.
I have reinstalled Quartus and Nios.
Maybee not the smartest way but now it works again.
I think the problem began when i changede my perl file, to a newer on.
Thanks for you quick reply Queisser.
/Imagine
