12602 Discussions
Problem in registering ISR (C++)
HI.
I'm doing my thesis on a DE2 board. I'm using a NIOS II processor. I've been writing all my source code in C. That way, it worked perfectly.
I had to ****ch to C++ for a few reasons (which I'm not gonna explain here). The thing is: I have some problems to register an ISR.
This is the "old" code (which works in C):
void simpler_isr() { for(j=0; j<3; j++) { store_array = IORD(FULL_CLASIFIER_0_BASE, 0x00); } i++; flag++; }
and this is the part where I register the isr:
alt_ic_isr_register(FULL_CLASIFIER_0_IRQ_INTERRUPT_CONTROLLER_ID, FULL_CLASIFIER_0_IRQ, simpler_isr, NULL, 0x0);
When I tried to compile in C++, I got this error mesage:
initializing argument 3 of `int alt_ic_isr_register(alt_u32, alt_u32, void (*)(void*), void*, void*)'
invalid conversion from `void (*)()' to `void (*)(void*)'
So, I changed the ISR this way:
void simpler_isr(void*) { for(j=0; j<3; j++) { store_array = IORD(FULL_CLASIFIER_0_BASE, 0x00); } i++; flag++; }
Now, I get this message:
Undefined reference to "main"
I don't know what I'm missing.
THANKS.
I respond myself:
I did a "make clean" and I solve the last problem. Now, I have another one.
It seems that the ISR registration never occurs. I put a cout next to alt_ic_isr_register, and it never appears on stdout (screen).
Any suggestions??
thanks
1. You can "debug" ;-)
2. stdout = screen ? sure ? Look at if it is not an UART instead of JTAG UART (or the opposite).
3. Maybe you use light drivers for printf or cout. I don't know the new (since 9.2) NIOS Software Built Tool.
Hello.
As I said, the project was written in C, and it worked.
The only thing I did was adding C++ stuff and "migrate" to a C++ project.
Greetings.
Are you sure that any of your code is now running?
Or it might all be dying horribly before the text is actually written to the uart.
Even in C++ I'd use use printf(), 'cout' adds an extra level complexity (and unusability) that might be masking things. If you suspect a lockup you need a synchronous write - not one that is buffered and/or requires interrupts to complete.
You might also need to mark the ISR as 'extern "C"' - but that would (probably) only affect the symbol name, not the address passed.
Hello.
I've just tried the simpler C++ program (Hello World) and it didn't work. I tried with cout, I tried with printf. The project compiles, but the program does nothing.
Once I compile the project, these are the commands I'm using:
nios2-download -g holamundo.elf
Using cable "USB-Blaster [USB 4-1.3]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 53KB in 1.0s (53.0KB/s)
Verified OK
Starting processor at address 0x008001C4
nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB 4-1.3]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
.... and nothing happens.
Ok,you meant to say code is downloaded ,you put printf after ISR declaration and nothing happens though all is perfectly fine as JTAG UART and all,right?
Do one thing,just put printf (or cout) immediately after main(),and see it displays on console when running.what happenes..!! It should display
If still not then delete whole file from the project (save backup somehere),clean and add it again.And manually RESET ur hardware or download SOF again and then run the code.
Hi Supal.
I had done everything you said. Nothing happened.
I'm starting thinking that is a problem related to the PC I'm using. I'm gonna try to do it in other PC.
Thanks!!!
Check if your output is really your UART.. double check the adresses and everything else.
I re-assigned the addresses via SOPC
I check by BSP editor, and:
stderr -> jtag_uart
stdin -> jtag_uart
stdout -> jtag_uart
I regenerated the BSP
I compiled the project
I downloaded (nios2-dowload -g project.elf). I ran nios2-terminal... and nothing happened... I don't really know what to do.
