12453 Discussions
Problem to use the USB OTG as gadget (peripheral) in linux.
hi
I'm using the helio board from macnica with a SoC Cyclone V and I'm trying use the USB OTG of the board as device (gadget) in the linux.
My target is connect the board to my PC and I want that my PC recognize the board as HID device or CDC device.
With a little search in the web I discovered that I need enable the module libcomposite.ko and the module g_serial.ko.
The kernel image that I use is from the site: http://rocketboards.org/foswiki/documentation/alterasocltsikernel. I have tryed with the kernel 3.13 and 3.18.
When I use the kernel 3.13, I get the error:
root@socfpga:~/drivers# insmod libcomposite.ko // OK no error
root@socfpga:~/drivers# insmod g_serial.ko
Error: could not insert module g_serial.ko: No such device
in the dmesg have the message:
couldn't find an available UDC
I suppose that the error is because don't have the UDC (USB device controller) driver, I try enable the flag Designware/S3C HS/OtG USB Device controller in the
→ Device Drivers → USB support → USB Gadget Support → USB Peripheral Controller to enable the driver.
but when I try it the kernel compilation brike with the error:
make[3]: *** No rule to make target `drivers/usb/gadget/s3c-hsotg.o', needed by `drivers/usb/gadget/built-in.o'. Stop.
The most interesting is that in the drivers/usb/dwc2/Makefile have the follow message:
# NOTE: This driver at present only implements the Host mode# of the controller. The existing s3c-hsotg driver supports# Peripheral mode, but only for the Samsung S3C platforms.# There are plans to merge the s3c-hsotg driver with this# driver in the near future to create a dual-role driver. Once# that is done, Host mode will become an optional feature that# is selected with a config option.
In the kernel 3.18 this structure of the kernel was changed, but I have the same error when try execute the module the command "insmod g_serial.ko".
Someone know if the Altera give drivers to use the OTG as peripheral in the linux? If yes how I can do it?
Willian Henrique
