Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Problem using DPRAM
I have problem using DPRAM..
I am connecting NIOS II with portB of altsyncram,
portA of altsyncram with external pin for my DPRAM.
I can connect NIOS with portB of altsyscram using SOPC Builder,
but I have problem connecting portA of altsyncram to external pin.
What I need to know is how to connect:
data_a[]
address_a[]
wren_a
q_a[]
and
addr[] (input)
data[] (bidir)
cs_n (input)
rw_n (input)
I tried connecting as follows:
addr[] <-> address_a[]
(cs_n nor rw_n)<->(wren_a)
and tried connecting
data[] <-> (data_a[], q_a[])
using lpm_bustri or tri, but cannot read & write well.
What actually happens is, it writes unexpected data
to unexpected places when I try read/write..
I think my problem is the way I am connecting
data[] <-> (data_a[],q_a[])
I also tried connecting the expernal pin to dff,
but would not work.
Any advice would be great.
