12603 Discussions
Problem using Flash Programmer
I have problem using Flash Programmer.
I am trying to write something to flash of my custom board,
but doesn't seem to work..
Below message appears:
[SOPC Builder]$ nios2-flash-programmer --input=xxx_fpga.flash --sof=d:/doors_h ome/xxx/xxx_board/system/xxx_board.sof --base=0x00800000
WARNING: Default charset MS932 not supported, using ISO-8859-1 instead Oct 6, 2005 8:32:57 PM - (??) nios2-flash-programmer: Launching Quartus Program er to download:
d:/doors_home/xxx/xxx_board/system/xxx_board.sof
Oct 6, 2005 8:33:01 PM - (???) nios2-flash-programmer: Error opening target har ware
Oct 6, 2005 8:33:01 PM - (???) nios2-flash-programmer: Unable to open flash-
evice after successfully communicating
with target.
It is likely that you are using a flash-programming FPGA design which was not created for your target board.
I think I am not doing totally wrong,
since I can write something into EPCS using nios2-flash-programmer,
and it seems to work just fine.
Any advice will be great.
--- Quote Start ---
originally posted by fuji@Oct 6 2005, 08:03 AM
hello,
i have problem using flash programmer.
i am trying to write something to flash of my custom board,
below message appears:
[sopc builder]$ nios2-flash-programmer --input=xxx_fpga.flash  --sof=d:/doors_h ome/xxx/xxx_board/system/xxx_board.sof --base=0x00800000
warning: default charset ms932 not supported, using iso-8859-1 instead oct 6, 2005 8:32:57 pm - (??) nios2-flash-programmer: launching quartus program er to download:
oct 6, 2005 8:33:01 pm - (???) nios2-flash-programmer: error opening target har ware
oct 6, 2005 8:33:01 pm - (???) nios2-flash-programmer:    unable to open flash-
with target.
it is likely that you are using a flash-programming fpga design which was not created for your target board.
i think i am not doing totally wrong,
since i can write something into epcs using nios2-flash-programmer,
any advice will be great.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10191)
--- quote end ---
--- Quote End ---
Hi fuji,
Sorry about the last post ... I fat-fingered it ... still getting used to the new buttons ;-)
Did you create the xxx_fpga.flash file with sof2flash? What parameters did you use?
--Scott
--- Quote Start ---
originally posted by smcnutt@Oct 6 2005, 09:26 AM
hi fuji,
sorry about the last post ... i fat-fingered it ... still getting used to the new buttons ;-)
did you create the xxx_fpga.flash file with sof2flash?  what parameters did you use?
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10195)
--- quote end ---
--- Quote End ---
Since it needs a file of <cuuston_board_name>.ptf
when programme flash, I think you must make this
file with the command of ma_target_board.
Thank you very much, smcnutt and eltonlaonong.
I think my problem is that the flash we use is NOT cfi flash.
The flash driver we made works good.
We had a cyclone evaluation board at hand,
so we made totally new files assumming this being a custom board,
and Flash Programmer worked just fine.
I guess there was nothing wrong with the procedures we took to make our own custom board.
I saw some posts with similar problem using non cfi flash.
Is there anyway I can use Flash Programmer on non cfi flash?
I&#39;m still waiting for an answer on that one. Basically, you&#39;d have to write your own flash programmer target code for your target board, but you have to know the flash programmer&#39;s protocol on the JTAG UART in order to do that.
I have replaced my non cfi flash to cfi flash,
Just wanted to let you know.
Which way should I use to write my program to the Flash on my customized development board?? using the JTAG of FPGA???
Thank you !!!!
I have the same problem, waiting for the answer!
I got around the problem by doing a separate configuration for the PLD, containing a small program in internal-ROM to accept the flash HEX data from a serial port and write programming instructions to the flash.
