Problem wid nios ii APIs
Hello all,
I'm using Quartus v13.1 on my DE2-70 board with the cyclone II fpga. I want to enable interrupts using toggle switches. It worked when using the Altera ehanced interrrupt API (#include"altera_avalon_pio_regs.h"), However I tried using the nios 2 API (because we have some tutorials using it ) and It does not seem to work. For eg:
I tried using the functions such as : __builtin_wrctl(3, 2) and __builtin_wrctl(0, 1) to write into the ienable and status register respectively. When i read the ipending register (ipending = __builtin_rdctl(4)) it shows 0 . I also tried replacing it with the nios 2 macros without much success. Here is the code i used:
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include "system.h"
#include "nios2.h"
volatile uint32_t *LED = (volatile uint32_t *) LEDS_BASE; /* Green leds base address*/
volatile uint32_t * slides = (volatile uint32_t *) 0x41000; /* slider switches base address*/
void toggle_isr()
int press;
press = *(slides+3); /* read the switch edge capture register*/
//*(slides+3) = 0; /* clear the interrupt */
printf("Hello from Nios 3! \n");
while(1)
printf("Hello from Nios I4! \n");
if ((press & (1 << 1)) != 0) /* SW[1] */
printf("Hello from Nios II! %d \n", *LED);
if(*LED == 0xFF)
*LED = 0;
(*LED)++;
usleep(100000);
void interrupt_handler(void)
int ipending, status;
printf("Hi! \n");
NIOS2_READ_STATUS(status);
printf("HhgfghfjhgfghfI! %d \n", status);
NIOS2_READ_IPENDING(ipending);
printf("Hello from Nios II! %d \n", ipending);
//if (((ipending & (1 << 1))) != 0 ) // toggle switches is interrupt level 1
if (ipending != 0) // checking for enabled interrupts in general*/
printf("Hello from Nios 2! %d \n", ipending);
toggle_isr();
// else, ignore the interrupt
return;
int main()
*(slides+2) = 0x3;
NIOS2_WRITE_IENABLE(0x2);
NIOS2_WRITE_STATUS(1); /* enable Nios II interrupts*/
interrupt_handler();
return 0;
Is there a reason why it is not working (errors in the code above, obsolete functions …)?
