12603 Discussions
Problem with GRAPHICS LCD Interface (128*64) for cyclone 3c120 device
Hi all,
I'm a novice programmer to interface graphics LCD (glcd) using cyclone iii 3c120 device.
The display is an Optrex part number F-51852GNFQJ-LB-CAN (Green Pixels).
128 × 64 dot matrix graphics LCD display.
I'm using Nios II Eclipse IDE to interface glcd with a C language based API.
The C source file is shown below(taken from 24931 post id):
# include<stdio.h># include <unistd.h># include "system.h"# include "altera_avalon_pio_regs.h"
void glcd_writeByte(int DI, int data)
if (DI == 1)
IOWR_ALTERA_AVALON_PIO_DATA(GLCD_D_CN_BASE, 0x01); //write a command;
else
IOWR_ALTERA_AVALON_PIO_DATA(GLCD_D_CN_BASE, 0x00); //write data;
IOWR_ALTERA_AVALON_PIO_DATA(GLCD_DATA_BASE, data); //put DATA on the data lines;
usleep(2); //wait 2 us
IOWR_ALTERA_AVALON_PIO_DATA(GLCD_WEN_BASE, 0x00); //pull the Write Enable pin low to enable writing to the LCD
IOWR_ALTERA_AVALON_PIO_DATA(GLCD_WEN_BASE, 0x01); //pull the ENABLE pin high to disable writing to the LCD
void glcd_init(void)
IOWR_ALTERA_AVALON_PIO_DATA(GLCD_RSTN_BASE, 0x00); // Hard reset
usleep(20); // Wait 20us;
IOWR_ALTERA_AVALON_PIO_DATA(GLCD_RSTN_BASE, 0x01); // Release reset;
usleep(100000); // Wait 100ms);
glcd_writeByte(0, 0xe2); // Internal Reset
glcd_writeByte(0, 0xa2); // Bias = 1/9; 0xa3 for 1/7
glcd_writeByte(0, 0xa1); // ADC = 1 (right to left); 0xa0 for 0(left to right)
glcd_writeByte(0, 0xc0); // Common direction = Normal; 0xc1 for inverse
glcd_writeByte(0, 0x28); // Set Power Control - Internal power circuits OFF ******* but looks better with 0x2f
glcd_writeByte(0, 0xe7); // Set Driver ON; 0xe6 for OFF
glcd_writeByte(0, 0xaf); // Display ON; 0xae for OFF
glcd_writeByte(0, 0xa5); // Entire Display ON - Turn ON all pixels (irrespective of RAM)
usleep(500000); // Wait 500ms
glcd_writeByte(0, 0xa4); // Entire Display NORMAL - Pixels correspond to display RAM
int main(void)
printf("Graphics LCD Display\n");
glcd_init();
GLCD Pin Specs:
LCD_DATA0: AA4
LCD_DATA1: AD1
LCD_DATA2: V8
LCD_DATA3: AB5
LCD_DATA4: AE2
LCD_DATA5: V5
LCD_DATA6: V6
LCD_DATA7: AB3
LCD_BS1: ??? Parallel Interface Selection*
LCD_CSn: AB24
LCD_D_Cn: D27
LCD_E_RDn: V7
LCD_RSTn: H7
LCD_WEn: AC4
LCD_SERn: ??? LCD Parallel/Serial DATA Select*
My SOPC system contains the following components:
  • NIOS II Processor
  • ON-Chip Memory 256Kb
  • JTAG UART
  • LCD_DATA
  • LCD_CSn (1-bit PIO)
  • LCD_D_Cn (1-bit PIO)
  • LCD_E_RDn (1-bit PIO)
  • LCD_RSTn (1-bit PIO)
  • LCD_WEn (1-bit PIO)
The above code doesn't change my gLCD Display. The display is same even after programming the hardware.
Please help me for interfacing gLCD.
NOTE: * denotes that there are no pin assignments specified as such in Cyclone III Dev Ref Manual. Also I have not assigned pins for the signals such as
  • LCD_BS1
  • LCD_SERn
TO_BE_DONE
--- Quote Start ---
After run this code, your GLCD will display ALTERA logo.
Any problem u can contact with me.
--- Quote End ---
I made all the steps described in this thread but my glcd still doesn't display anything. I know i'm doing something wrong but i don't know what it is.
I used your NIOS program and also used the system described by samratv with that pin assignment. I have the F-51852GNFQJ-LB-AIN (Blue pixels), is that why it doesn't work for me??
Thnxs
