After menuconfig I have done this :
$ ~/uclinux-dist$ make vendor_hwselect sysptf=/home/samratv/desktop/de2_nios_device_led/hw/system_0.ptfmake ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C vendors vendor_hwselect make[1]: Entering directory `/home/samratv/uClinux-dist/vendors' make -C /home/samratv/uClinux-dist/vendors/Altera/nios2nommu/. dir_v=/home/samratv/uClinux-dist/vendors/Altera/nios2nommu/. -f /home/samratv/uClinux-dist/vendors/vendors-common.mak vendor_hwselect make[2]: Entering directory `/home/samratv/uClinux-dist/vendors/Altera/nios2nommu' make[2]: *** No rule to make target `vendor_hwselect'. Stop. make[2]: Leaving directory `/home/samratv/uClinux-dist/vendors/Altera/nios2nommu' make[1]: *** [vendor_hwselect] Error 2 make[1]: Leaving directory `/home/samratv/uClinux-dist/vendors' make: *** [vendor_hwselect] Error 2 why did i get those errors ? i have specified the path correctly. Please help.
Still no answer? As I have the same problem ....
