Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
12471 Discussions
Problem with IRQs. Linux freezing.
Hello i've made a design consisting of a CPU, SDRAM, PHY and etc.
Then i made a character device driver to recieve IRQs from a VHDL block i've made, my VHDL block generates a high signal at a 60hz frequency.
However my Linux freezes after a certain time (like 1minute), why is that?
If i comment the line in my device driver that register the IRQ everything works fine and the linux never freezes!
My device driver implementation is the follow:
Read function:
ssize_t shmem_read(struct file *filep ,char *buff, size_t count, loff_t *offp) { int retval; int temp = 0; interruptible_sleep_on(&readw); retval = copy_to_user(buff, &current_cycle, sizeof(raw_cycle_t)); if (retval != 0) { printk(KERN_ERR "Kernel to userspace copy failed!\n" ); return retval; } return count; }
IRQ handler
static irqreturn_t io_irq_handler(int irq, void *dev_id) { wake_up_interruptible(&readw); outl(0xf, &pio_in->np_pioedgecapture); return IRQ_HANDLED; }
INIT_IRQ
/* IRQ PIO INPUT INIT */ io_irq = PIO_IRQ; enable_irq(io_irq); ret = request_irq(io_irq, &io_irq_handler, 0, DRIVER_NAME, &io_irq); if (ret) { printk(KERN_ERR __FILE__ ": Error while requesting IRQ, during %s\n", __FUNCTION__); return ret; }
I guess i was having a deadlock.. when i run it with realtime process priority i have no problems.
EDIT:
NVM just had the same problem after a longer time..
I changed my PIO irq from Level to Edge and everything works fine
