Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Problem with UBIFS (NOR flash) in uClinux
I'm trying use UBIFS in my board because I had problem with JFFS2, after some writes in JFFS2 I can't write anymore and shows a message:
MTD do_write_oneword(): software timeout
Write of 188 bytes at 0x005fc078 failed. returned -5, retlen 0
Not marking the space at 0x005fc078 as dirty because the flash driver returned o
Because this problem I'm trying UBIFS.
I use a NOR FLASH with 8MB (S29JL064H) and uClinux kernel 2.30
In the kernel is enabled
config.c (Flash partitions)
.name = "romfs",
.size = 0x600000,
.offset = 0x200000,
.name = "loader/kernel",
.size = 0x200000,
.offset = 0,
--- Memory Technology Device (MTD) support
[ ] Debugging
< > MTD concatenating support
[*] MTD partitioning support
<*> Enable UBI
(4096) UBI wear-leveling threshold
And in Miscellaneous filesystems
<*> UBIFS file system support
In the kernel boot :
(rootfstype=ubifs ubi.mtd=0 root=ubi0:rootfs) Default kernel command
For create a ubifs image I used
cat ubinize.cfg
[ubifs]
mode=ubi
image=ubifs.img
vol_id=0
vol_size=4MiB
vol_type=dynamic
vol_name=rootfs
vol_alignment=1
vol_flags=autoresize
mkfs.ubifs -d romfs -m 1 -e 65408 -c 128 -o ubifs.img -D device_table.txt
ubinize -o ubi.img -m 1 -p 64KiB -v ubinize.cfg
Everthing is allrigth , to create a .flash I use the commands
bin2flash --input=ubi.img --location=0x200000 --output=ubi.flash
nios2-flash-programmer --base=0x2000000 --erase-all (format flash)
nios2-flash-programmer --base=0x2000000 ubi.flash
After this I tried boot with my kernel
nios2-download -g zImage
After the boot I have a kernel panic
uClinux/Nios II
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 2032
Kernel command line: rootfstype=ubifs ubi.mtd=0 root=ubi0:rootfs
NR_IRQS:32
PID hash table entries: 32 (order: 5, 128 bytes)
Dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 5804k/2107k RAM, 0k/0k ROM (1747k kernel code, 360k data)
Calibrating delay loop... 63.89 BogoMIPS (lpj=319488)
Mount-cache hash table entries: 512
net_namespace: 264 bytes
NET: Registered protocol family 16
init_BSP(): registering device resources
bio: create slab <bio-0> at 0
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
io scheduler noop registered
io scheduler deadline registered (default)
ttyS0 at MMIO 0x2810000 (irq = 3) is a Altera UART
console [ttyS0] enabled
ttyS1 at MMIO 0x2810060 (irq = 4) is a Altera UART
IIPDEV Driver Initialized
SYSDEV Driver Initialized
TXTABLEDEV Driver Initialized
RXTABLEDEV Driver Initialized
ALARMDEV Driver Initialized
smc91x.c: v1.1, sep 22 2004 by Nicolas Pitre <nico@cam.org
eth0: SMC91C11xFD (rev 2) at 82800300 IRQ 2 [nowait]
eth0: Ethernet addr: 00:11:22:33:44:55
physmap platform flash device: 00800000 at 02000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash.0: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using physmap partition information
Creating 2 MTD partitions on "physmap-flash.0":
0x000000200000-0x000000800000 : "romfs"
0x000000000000-0x000000200000 : "loader/kernel"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size: 65536 bytes (64 KiB)
UBI: logical eraseblock size: 65408 bytes
UBI: smallest flash I/O unit: 1
UBI: VID header offset: 64 (aligned 64)
UBI: data offset: 128
UBI: volume 0 ("rootfs") re-sized from 65 to 92 LEBs
UBI: attached mtd0 to ubi0
UBI: MTD device name: "romfs"
UBI: MTD device size: 6 MiB
UBI: number of good PEBs: 96
UBI: number of bad PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 96
UBI: number of PEBs reserved for bad PEB handling: 0
UBI: max/mean erase counter: 1/0
UBI: background thread "ubi_bgt0d" started, PID 20
m25p80 spi0.0: m25p16 (2048 Kbytes)
Creating 1 MTD partitions on "m25p80":
0x000000000000-0x000000200000 : "fpga configuration"
i2c /dev entries driver
i2c-0: I2C OpenCores Bus Adapter, MMIO = 0x20, irq = 0
i2c-0: Using 16003kHz clock source
TCP cubic registered
NET: Registered protocol family 17
UBIFS error (pid 1): ubifs_check_node: bad CRC: calculated 0x914d95fa, read 0x3c
UBIFS error (pid 1): ubifs_check_node: bad node at LEB 0:0
UBIFS error (pid 1): ubifs_read_node: expected node type 6
VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Someone have some ideia?
Caio Pereira
