12603 Discussions
Problem with burstcount > 2 for Avalon MM Master to SDRAM
I am trying to implement a burst transcation with SDRAM using Avalon MM Interface.
The following Verilog code works fine for burstcount = 2:
module hw_det_3by3( clk, reset, avs_csr_addr, avs_csr_write, avs_csr_writedata, avs_csr_read, avs_csr_readdata, avm_sdram_addr, avm_sdram_burstcount, avm_sdram_read, avm_sdram_waitrequest, avm_sdram_readdatavalid, avm_sdram_readdata ); input wire clk; input wire reset; input wire avs_csr_addr; input wire avs_csr_write; input wire avs_csr_writedata; input wire avs_csr_read; output wire avs_csr_readdata; output wire avm_sdram_addr; output wire avm_sdram_burstcount; output wire avm_sdram_read; input wire avm_sdram_waitrequest; input wire avm_sdram_readdatavalid; input wire avm_sdram_readdata; reg read_addr; reg load_minors = 0; reg count = 0; reg status = 0; reg minor10; reg minor11; reg minor12; reg minor20; reg minor21; reg minor22; reg sdram_read; reg csr_readdata; assign avm_sdram_addr = read_addr; assign avm_sdram_burstcount = 2; assign avm_sdram_read = sdram_read; assign avs_csr_readdata = csr_readdata; always @ (posedge clk) begin if (avs_csr_write == 1) begin if (avs_csr_addr == 1) begin load_minors <= 1; read_addr <= avs_csr_writedata; end end if (load_minors == 1) begin load_minors <= 0; end end always @ (posedge clk) begin if (load_minors == 1) begin sdram_read <= 1; end else begin if (avm_sdram_waitrequest == 0) begin sdram_read <= 0; end end end always @ (posedge clk or posedge reset) begin if (reset == 1) begin count <= 0; status <= 0; end else if(avm_sdram_readdatavalid) begin case (count) 0: begin minor10 <= avm_sdram_readdata; end 1: begin minor11 <= avm_sdram_readdata; status <= 1; end endcase count <= count + 1; end end always @ (posedge clk) begin if(avs_csr_read == 1) begin case (avs_csr_addr) 0: csr_readdata <= status; 1: csr_readdata <= read_addr; 2: csr_readdata <= minor10; 3: csr_readdata <= minor11; endcase end end endmodule
Software Interface in NIOS:
#include <stdio.h># include "system.h"# include <io.h># include <stdlib.h> /* rand(), RAND_MAX */ int main() { float n = 1.25; float m = 2.5; printf("%x, %x\n", &n, &m); IOWR(HW_DET_3BY3_0_BASE, 1, &n); while (IORD(HW_DET_3BY3_0_BASE, 0) == 0){ printf("%x\n", IORD(HW_DET_3BY3_0_BASE, 0)); } printf("%x\n", IORD(HW_DET_3BY3_0_BASE, 1)); printf("%x\n", IORD(HW_DET_3BY3_0_BASE, 2)); printf("%x\n", IORD(HW_DET_3BY3_0_BASE, 3)); return 0; }
However, when I make slight variations to implement the same functionality for a burst of 3 words, then I get problems - 'status' never changes to 1.
Does anyone have an idea why that is? I have been trying to solve this for the past few hours now...
Also, is there are a possibility I can monitor my signals (avm_sdram_writerequest, avm_sdram_readdatavalid etc.) during runtime?
Many thanks in advance.
Jimmy
Have a look at the signal tap logic analyzer included in Quartus. Very useful for tracking down this kind of thing and it will allow you to see the signals in action and trigger on their state.
Mark.
Many thanks for the tip, this already helped me to identify several mistakes.
Is there also a tool to monitor SDRAM content at runtime?
Had a look at In-System Memory Content Editor, but seems like it only supports on-chip memory... (I am using the SDRAM Controller Component in Quartus).
You could make an Avalon master that reads an address. Connect both that and your other stuff to the memory - Qsys will take care of adding arbitration. Or get your "test" master to read through a range of address and monitor the results with SignalTap.
Mark.
I would just simulate your design so that you can view everything to perform proper debug.
Although I'm not sure why the status bit does not assert, I think you want your count register to be two bits wide otherwise you will end up overriding the value in minor10 due to count register rolling over.
