Problems Starting IDE
I'm starting a new NIOS II software project use the NIOS II IDE.
It's a blank project using the wizard. For my target hardware I select the ptf file created by the Quartus tools.
When I'm at the last step I get the following error message.
Invalid project description.
D:/Alarmco/2004/PermaPlay/FPGA/Cyclone/V2V00-17/software/dhrystone_0_syslib and D:/Alarmco/2004/PermaPlay/FPGA/Cyclone/V2V00-17/software overlap.
Any clues as to what's wrong??
gm
I don't quite understand it, but after running into this many times, I have found that what you really want to do is "create new C/C++ application", not project.
A good explanation of "what is a project", "what is an application" is needed.
I can not create a new "c/c++ Appliation". I get the same error message.
Anyone have any ideas.
gm
Can anyone help my out?
I've built a NIOS II in a Cyclon FPGA using SOPC and the latest quartus.
I'm trying to start the IDE and create a software projecy.
I've tried both the New Project wizard and New C/C++ Wizard.
Both give me the same error message
I've tried all the different types of projects and all give the same error message.
I can find the ptf file and the proper cpu in that file.
I'm dead in the water.
Help [a not so happy simely face goes here!!!]
george
Well I've solved this one.
tns1 was correct it's all a mystery on projects and applications with no good explaination.
The Navigator Pane has Navigator and Projects Tabs.
Selecting the projects tab let me see the projects I had created as I was experimenting with the IDE.
Deleting those projects and starting freas solved my error messages.
MORE DOCUMENTATION IS NEEDED.
George
