12600 Discussions
Problems with EPCS controller
Greetings,
I am using SOPC builder to build a system that contains an EPCS controller.
I am running a bare bones program to talk to the EPCS part natively using
the functions specified in the epcs_commands.c file.
The first function I call is epcs_read_status_register(). This function in
turn calls alt_avalon_spi_command(). My program gets stuck in the
alt_avalon_spi_command() function and does not return.
Specifically here is where it gets stuck:
do
status = IORD_ALTERA_AVALON_SPI_STATUS(base);
while (((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0 || credits == 0) &&
(status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0);
It never leaves this do/while loop.
If I have an EPCS conrtoller and an EPCS part and am using the correct
base address is there any reason that I would be having this problem?
Any and all information helpful.
Look to the sources of epcs controller...
I has the same problem too - i solve it when i find in epcs_controller.v file
string where i saw the switch - it menas if you set address where bit 8 is 1 - you can access to epcs chip if bit 8 is 0 you can read only boot rom onchip memory.
If you want to get more details let me know. I can send to you my sources for epcs
--- Quote Start ---
--- Quote End ---
Hello!
I have the same problem too. When i use epcs_commands.c ,i found the program stop in do/while loop.
I scanned the sources of epcs_controller.v(My file name is NIOS_CPU_NIOS_EPCS.v). But I am not know how to modify to solve the problem. Could you help me how to solve this problem?
Thank you!
