I'm using two DE0 board to communicate with SPI core. One configued as master and another as slave. I tried to check spi status register to complement the slave code. And whole process is the master send data-- 0xabcd,and the slave receive the data and send back. But I found that the master can't receive the right data sometimes, less than 50% time the received data is right. I run the master program with debug mode first and then run the slave one to avoid signal toggle on the slave's input side. I set SCLK from 128kHz to 1MHz,the problem is still there. Here is my code for slave: int main(void) { alt_u32 rddata=0x0; alt_u32 status; IOWR_ALTERA_AVALON_SPI_STATUS(SPI_BASE,0x0000); IOWR_ALTERA_AVALON_SPI_TXDATA(SPI_BASE,0x1001); IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); while(1) { do { status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE); } while((status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK)==0 && (status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0); rddata= IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); IOWR_ALTERA_AVALON_SPI_TXDATA(SPI_BASE, rddata); } Code for master is : int main(void) { void send(alt_u16 write); alt_u16 receive(); alt_u16 wrdata=0xabcd; alt_u16 rddata; IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(SPI_BASE, 1); IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); while(1) { send(wrdata); rddata=receive(); } return 0; } void send(alt_u16 write) { alt_u32 status; alt_u16 data; IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0x0400); IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); do { status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE); } while (((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0)&& (status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0); IOWR_ALTERA_AVALON_SPI_TXDATA(SPI_BASE , write); data=IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); do { status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE); } while ((status & ALTERA_AVALON_SPI_STATUS_TMT_MSK) == 0); IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0); } alt_u16 receive() { alt_u16 data; alt_u32 status; IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0x0400); IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); do { status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE); } while (((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0 ) && (status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0); IOWR_ALTERA_AVALON_SPI_TXDATA(SPI_BASE , 0x00); data=IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); do { status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE); } while ((status & ALTERA_AVALON_SPI_STATUS_TMT_MSK) == 0); IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0); return data; } Can anybody help on this problem? I think there maybe some mistake in my code. Has anybody use SPI core as a slave? Most people use the SPI core as a master, I really need some on the slave mode. Thank a lot!Link Copied
hi truefrank,
I checked your code and it is working fine for DE2-115 board.
