12604 Discussions
Problems with Web Server(RGMII) template (it keeps restarting!)
Hi all,
I am working on a custom board which has a Stratix iv FPGA and a Micrel KSZ9021 ethernet phy.
The hardware design is the same as the triple speed ethernet example which includes TSE MAC, SGDMA, and DDR3.
As to the Nios II code, I use the web server(RGMII) template and modify it a little bit.
The modification I did is: 1. hard coded the MAC address(instead of reading from flash) and use static IP
2. comment out the LED tasks and so on to simply test the ethernet connection
3. wrote a driver for the phy and plug it in the altera_avalon_tse.c
Everything compiles fine and initialization is successful as the outputs below shows:
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Your Ethernet MAC address is 00:07:ed:ff:8f:12
Static IP Address is 172.16.8.207
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x20012000
INFO : PHY MICREL KSZ9021 found at PHY address 0x07 of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
micrel : Enable RGMII Timing Control
micrel : Auto-Negotiation PASSED
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x04000203
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 172.16.8.207
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
Created "web server" task (Prio: 4)
Web Server starting up
However, the strange thing is when I ping the IP, the host receives the first reply, misses the second one, then receives the third one and so on.
And I find the problem behind it is that every time the program receives a ping, the main function restarts and everything gets re-initialized including the phy!
I've tried to trace the whole program in debug mode but couldn't locate the problem.
I have to admit I'm pretty new to micro-OS and InterNiche and need suggestions in solving this problem.
Thank you in advance!
Neal
Dear Neal,
I'm working on the DE1-SoC board, and I have to make a driver to initialize the ethernet controller, I have the same controller that you are using. I'm very grateful if you can share the driver of the micrel KSZ9021
Thank you
Gianluca
--- Quote Start ---
Hi all,
prep_tse_mac 0
[tse_mac_init]
mctest init called
Neal
--- Quote End ---
