12603 Discussions
Problems with installing Nios2 Linux
I am attempting to install the Nios2 Linux development tools on a Centos 6.3 based system.
I am somewhat confused by the instructions (on alteras wiki: Install_Nios_II_Linux). They indicate that the test-nios2 branch is the current branch of the kernel, but the nios2-linux-20100621.tar doesn't come automatically configured for this branch. The instructions also indicate that the current kernel uses the Devicetree approach to configuring the kernel for hardware, though, if I build with the test-nios2 branch, I have to use the vendor_hwselect mechanism
Can someone tell me what the current branch is (test-nios2 or nios2mmu under linux-2.6 and test-nios2 or trunk under uClinux-dist) and what the current hardware customization mechanism is (vendor_hwselect, devicetree or sopc generated header)?
Also, assuming that the current hardware customization is something other than vendor_hwselect, how do I configure things to get it?
Thanks in advance. I'm trying to get ready to use this in a college class that starts at the end of September.
D.W. Lynn
For reference, Here is what I did, working from the Install_Nios_II_Linux instructions on the wiki, specifically using nios2-linux-20100621.tar.
The tool-chain build step first complained:
/home/lynnd/nios2-linux/toolchain-build/u-boot.mk:11: Board not defined! Using EP1S10 as default.
and later fails with the following:
home/lynnd/nios2-linux/uClibc'
make[2]: `conf' is up to date.
CC libpthread/linuxthreads.old/cancel.o
In file included from ./include/sys/syscall.h:34,
from libpthread/linuxthreads.old/restart.h:16,
from libpthread/linuxthreads.old/cancel.c:23:
./include/bits/syscalls.h:10:23: asm/traps.h: No such file or directory
make[1]: *** [libpthread/linuxthreads.old/cancel.o] Error 1
make[1]: Leaving directory `/home/lynnd/nios2-linux/uClibc'
make: *** [/home/lynnd/nios2-linux/toolchain-build/../uClibc/lib/libc.a] Error 2
So, I switched to the prebuild binary toolchain, which worked. Then I attempted to make the kernel per the instructions using the make menuconfig process. There were lots of undefaulted options. On the final kernel make, I had to do "make CROSS-COMPILE=nios2-linux- since the default CROSS_COMPILE was nios2-linux-gnu-
and that's not how the binary toolchain installed and I couldn't find the CROSS_COMPILE option in make menuconfig kernel customization.
However, I still got the following error:
/home/lynnd/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S: Assembler messages:
/home/lynnd/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:542: Error: expecting control register
/home/lynnd/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:542: Error: unknown register r6
make[3]: *** [arch/nios2/kernel/entry.o] Error 1
Following some hints elsewhere in the forum, I removed the nios2-linux/ directory completely and untarred nios2-linux-20100621.tar again (to start fresh). Then,
before doing the ./checkout step, I did "git checkout test-nios2 -f" in both the uClinux and the linux-2.6 directories.
Now the kernel make process succeeds even though it uses the vendor_hwselect mechanism. Note that the documentation for Devicetree (linux-2.6/Documentation/devicetree) does not exist in the test-nios2 branch and make menuconfig in this branch does not give options for using the Device tree approach (that I could find).
'entry.S: Error: unknown register r6'
makes me worried too.
All you need to instal nios2-linux is to install following packages: git-all git-gui make gcc ncurses-devel bison byacc flex gawk gettext ccache zlib-devel gtk2-devel lzo-devel pax-utilslibglade2-devel uboot-tools
Next you need download from git all needed sources:
git clone -b trunk git://sopc.et.ntust.edu.tw/git/uClinux-dist.git
git clone git://sopc.et.ntust.edu.tw/git/toolchain-mmu.git
git clone git://sopc.et.ntust.edu.tw/git/linux-2.6.git
git clone git://sopc.et.ntust.edu.tw/git/tools.git
Now you need to set eviroment path in .bashrc file. My looks like follows:
QUARTUS=/home/kamil/altera/12.1/quartus
export QUARTUS
NIOS2EDS=/home/kamil/altera/12.1/nios2eds
export NIOS2EDS
SOPC_KIT_NIOS2=/home/kamil/altera/12.1/nios2eds
export SOPC_KIT_NIOS2
NIOS2LINUX=/home/kamil/uClinux
export NIOS2LINUX
PATH=$QUARTUS/bin:$QUARTUS/sopc_builder/bin:$NIOS2EDS:$NIOS2LINUX/toolchain-mmu/x86-linux2/bin:/usr/bin:$PATH
export PATH
In that way I have path for every tool from Altera like also for toolchain for nios2-uclinux.
Last step is to make sopc2dts tool. Just do "make" command in /tools/sopc2dts/ location (for that you need jdk-devel package)
And that is all. Now you can play with linux on your nios2 boards :)
--- Quote Start ---
export QUARTUS
export NIOS2EDS
export NIOS2LINUX
export PATH
--- Quote End ---
I get the same incomprehensible error
/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S: Assembler messages: /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: unknown register r5 /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:546: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:546: Error: unknown register r6 make: *** Error 1 make: *** Error 2 make: *** Error 2 make: Leaving directory `/home/developer/altera/nios2-linux/linux-2.6' make: *** Error 1
I already tried everything.
--- Quote Start ---
--- Quote End ---
Do you have any destroied files under the directory "arch/nios2/include/asm" ? Please check out 'entry.h’ or 'system.h' especially for the instruction 'rdctl' and 'wrctl'.
Kazu
--- Quote Start ---
Kazu
--- Quote End ---
In entry.h, it seems normal
#ifdef CONFIG_MMU rdctl r24,estatus
I wonder if there could be something wrong with my toolchain? I use the pre-built toolchain and I first didn't include `nios2-linux/toolchain-mmu/x86-linux2/bin`
If I do include the aforementioned path then I get a different error.
I installed the pre-built toolchain in `opt/nios2/bin`
in entry.h the wrctl instruction is just
wrctl estatus,r24
Any idea what I could do to make it build cleanly?
My PATH is
echo $PATH /usr/bin:/home/developer/eclipse/java-neon/eclipse:/home/developer/altera/nios2-linux/toolchain-mmu/x86-linux2/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/developer/Downloads/NuSMV-2.6.0-Linux/bin:/snap/bin:/opt/nios2/bin
I also installed gcc 4.2 with the multilib for 4.2. I think I did everything right, still it won't build.
--- Quote Start ---
wrctl estatus,r24
My PATH is
--- Quote End ---
The message
is made in the function
/* The function consume_arg takes a pointer into a string of instruction tokens (args) and a pointer into a string representing the expected sequence of tokens and separators. It checks whether the first argument in argStr is of the expected type, throwing an error if it is not, and returns the pointer argStr. */ char * nios2_consume_arg (char *argStr, const char *argType) { char *temp; int regno = -1; switch (*argType) { case 'c': if (strncmp (argStr, "ctl", strlen ("ctl")) != 0 && strncmp (argStr, "cpuid", strlen ("cpuid")) != 0 && strncmp (argStr, "status", strlen ("status")) != 0 && strncmp (argStr, "estatus", strlen ("estatus")) != 0 && strncmp (argStr, "bstatus", strlen ("bstatus")) != 0 && strncmp (argStr, "ienable", strlen ("ienable")) != 0 && strncmp (argStr, "ipending", strlen ("ipending")) != 0 && strncmp (argStr, "exception", strlen ("exception")) != 0 && strncmp (argStr, "pteaddr", strlen ("pteaddr")) != 0 && strncmp (argStr, "tlbacc", strlen ("tlbacc")) != 0 && strncmp (argStr, "tlbmisc", strlen ("tlbmisc")) != 0 && strncmp (argStr, "fstatus", strlen ("fstatus")) != 0 && strncmp (argStr, "config", strlen ("config")) != 0 && strncmp (argStr, "mpubase", strlen ("mpubase")) != 0 && strncmp (argStr, "mpuacc", strlen ("mpuacc")) != 0 && strncmp (argStr, "badaddr", strlen ("badaddr")) != 0) { as_bad (_("expecting control register")); } break;
of file "tc-nios2.c". So I think that you are calling the genuine nios2's 'gas'.
Please try to compile the 'entry.S' only, by evoking the 'nios2-***-gcc' or 'nios2-***-as' directly ?
Kazu
--- Quote Start ---
The message
Kazu
--- Quote End ---
This is what happens
$ nios2-linux-uclibc-gcc linux-2.6/arch/nios2/kernel/entry.S linux-2.6/arch/nios2/kernel/entry.S:35:23: linux/sys.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:36:27: linux/linkage.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:37:29: asm/asm-offsets.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:38:28: asm/asm-macros.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:39:29: asm/thread_info.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:42:23: asm/entry.h: No such file or directory linux-2.6/arch/nios2/kernel/entry.S:44:27: asm/processor.h: No such file or directory
--- Quote Start ---
--- Quote End ---
Please try
nios2-linux-uclibc-gcc -c -I/home/developer/altera/nios2-linux/linux-2.6/include -I/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S
. And I think that you should better learn compiler switches.
Kazu
Thanks for the help but I'm only getting more and more errors.
$ nios2-linux-uclibc-gcc -c -I/home/developer/altera/nios2-linux/linux-2.6/include -I/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include -I/home/developer/altera/nios2-linux/uClinux-dist/linux-2.6.x/include /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h: Assembler messages: /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:82: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:83: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:84: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:85: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:86: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:87: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:88: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:89: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:90: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:91: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:92: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:93: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:94: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:95: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:96: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:97: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:98: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:99: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:100: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:101: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:102: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:103: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:105: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:107: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:111: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:117: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:118: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:119: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:120: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:121: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:122: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:123: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:124: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:125: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:126: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:127: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:128: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/ptrace.h:129: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:62: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:63: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:66: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:67: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:69: Error: unrecognised instruction unsigned /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:71: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:90: Error: unrecognised instruction extern /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:92: Error: unrecognised instruction struct /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:95: Error: unrecognised instruction static /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:96: Error: junk at end of line, first unrecognized character is `{' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:97: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:100: Error: unrecognised instruction static /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:101: Error: junk at end of line, first unrecognized character is `{' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:102: Error: junk at end of line, first unrecognized character is `}' /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:107: Error: unrecognised instruction extern /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/processor.h:112: Error: unrecognised instruction extern /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:124: Error: unrecognised instruction save_all /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: unknown register r5 ...
--- Quote Start ---
--- Quote End ---
Please add -D name option switches like
nios2-linux-uclibc-gcc -c -D __ASSEMBLY__ -D __KERNEL__ -I/home/developer/altera/nios2-linux/linux-2.6/include -I/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include -I/home/developer/altera/nios2-linux/uClinux-dist/linux-2.6.x/include /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S
Some include files are used as mixed C and assembly codes. So there is the# ifndef __ASSEMBLY__ macro like
14# define _ASM_NIOS2_PTRACE_H 15 16# include <uapi/asm/ptrace.h> 17 18 /* This struct defines the way the registers are stored on the 19 stack during a system call. */ 20 21# ifndef __ASSEMBLY__ 22 struct pt_regs { 23 unsigned long r8; /* r8-r15 Caller-saved GP registers */ 24 unsigned long r9; 25 unsigned long r10; 26 unsigned long r11; 27 unsigned long r12; 28 unsigned long r13;
Kazu
--- Quote Start ---
Kazu
--- Quote End ---
That takes me back where I started:
$ nios2-linux-uclibc-gcc -c -D __ASSEMBLY__ -D __KERNEL__ -I/home/developer/altera/nios2-linux/linux-2.6/include -I/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include -I/home/developer/altera/nios2-linux/uClinux-dist/linux-2.6.x/include /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S: Assembler messages: /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:138: Error: unknown register r5 /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:546: Error: expecting control register /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S:546: Error: unknown register r6
--- Quote Start ---
--- Quote End ---
This means that there is no problem around the search path. So what code do you have at line 138 and 546 of 'entry.S' ?
Kazu
--- Quote Start ---
Kazu
--- Quote End ---
It's use of the rdctl register.
138: rdctl r5,exception
546: rdctl r6,badaddr
The whole file is pasted at http://stackoverflow.com/questions/42778812/error-unknown-register-when-building-uclinux
--- Quote Start ---
--- Quote End ---
Please try to preprocess the 'entry.S' with -E switch instead of -c, like
nios2-linux-uclibc-gcc -E -D __ASSEMBLY__ -D __KERNEL__ -I/home/developer/altera/nios2-linux/linux-2.6/include -I/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include -I/home/developer/altera/nios2-linux/uClinux-dist/linux-2.6.x/include /home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S > entry.txt
and check the output file by your editor whether the code 'rdctl r5,exception' and 'rdctl r6,badaddr' are transferd invariantly. Note that with the -E switch, the compiler uses the standard output for its output.
If the preprocessing is normal, then make a test file like
// test.S rdctl r5,exception rdctl r6,badaddr
and compile it.
nios2-linux-uclibc-gcc -c test.S
Does it genarate errors?
Kazu
--- Quote Start ---
and compile it.
Kazu
--- Quote End ---
Yes, the file test.S generates the same errors. Using the -E switch generated output difficult for me to understand
# 1 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S"# 1 "<built-in>"# 1 "<command line>"# 1 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S"# 35 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S"# 1 "/home/developer/altera/nios2-linux/linux-2.6/include/linux/sys.h" 1# 36 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S" 2# 1 "/home/developer/altera/nios2-linux/linux-2.6/include/linux/linkage.h" 1 # 1 "/home/developer/altera/nios2-linux/linux-2.6/include/linux/compiler.h" 1# 5 "/home/developer/altera/nios2-linux/linux-2.6/include/linux/linkage.h" 2# 1 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/linkage.h" 1# 6 "/home/developer/altera/nios2-linux/linux-2.6/include/linux/linkage.h" 2# 37 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S" 2# 1 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/asm-offsets.h" 1# 1 "/home/developer/altera/nios2-linux/uClinux-dist/linux-2.6.x/include/generated/asm-offsets.h" 1# 2 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/asm-offsets.h" 2# 38 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/kernel/entry.S" 2# 1 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/asm-macros.h" 1# 33 "/home/developer/altera/nios2-linux/linux-2.6/arch/nios2/include/asm/asm-macros.h" .macro ANDI32 reg1,reg2,mask .if \mask & 0xffff .if \mask & 0xffff0000 movhi \reg1,%hi(\mask) movui \reg1,%lo(\mask) and \reg1,\reg1,\reg2 .else andi \reg1,\reg2,%lo(\mask) .endif .else andhi \reg1,\reg2,%hi(\mask) .endif .endm .macro ORI32 reg1,reg2,mask .if \mask & 0xffff .if \mask & 0xffff0000 orhi \reg1,\reg2,%hi(\mask) ori \reg1,\reg2,%lo(\mask) .else ori \reg1,\reg2,%lo(\mask) .endif .else orhi \reg1,\reg2,%hi(\mask) .endif .endm
--- Quote Start ---
--- Quote End ---
Please try to compile the next code.
// test_ctl.S rdctl r5,ctl7 rdctl r6,ctl12
The names 'exception' and 'badaddr' are alias of control registers 'ctl7' and 'ctl12'.
Kazu
--- Quote Start ---
Kazu
--- Quote End ---
That seemed to compile:
$ nios2-linux-uclibc-gcc -c ctl.S developer@1604:~/altera/nios2-linux/uClinux-dist$ ls auto.conf config Documentation lib README test.S autoconf.h config.arch entry.txt linux-2.6.x release_notes testsuites bfin_patch COPYING freeswan MAKEALL romfs tools bin ctl.o images Makefile SOURCE user ccache ctl.S Kconfig openswan staging vendors
--- Quote Start ---
--- Quote End ---
It seems a compiler's bug. So please rewrite the control registers of 'entry.S' with ctl7 and ctl12.
Kazu
--- Quote Start ---
Kazu
--- Quote End ---
Thanks. It compiles now until the next bug: kernel/built-in.o(.text+0x2ea40): In function `get_update_sysctl_factor': : undefined reference to `____ilog2_NaN' kernel/built-in.o(.text+0x2ea40): In function `get_update_sysctl_factor': : relocation truncated to fit: R_NIOS2_CALL26 ____ilog2_NaN make: *** Error 1 make: *** Error 2 make: Leaving directory `/home/developer/altera/nios2-linux/linux-2.6' make: *** Error 1
--- Quote Start ---
--- Quote End ---
This is a long term bug which is caused by using the compiler optimization algorithm. ____ilog2_NaN is inserted to check the sanity of variable, and this function is eliminated during the optimization in normal situations, so the kernal will not call it actually. But it seems that they have finally given up this doubtful method.
http://www.mail-archive.com/linux-kernel@vger.kernel.org/msg1340693.html
So, please try to delete the function ____ilog2_NaN from the file 'include/linux/log2.h' according to the diff contents which is written in the last part of its mail.
Kazu
