Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Problems with the header <iostream.h>
Hello, I need help with the inclusion of the header file <iostream.h> because I&#39;ve a following problem:
My application has two Include Paths Containers in the directories:
C:\altera\kits\nios2\bin\eclipse\plugins\com.microtronix.nios2linux.uClibc_1.4.0
C:\altera\kits\nios2\bin\nios2-gnutools\H-i686-pc-cygwin\lib\gcc\nios2-elf\3.4.1\include
but when I built project appeared the following message of error:
make -k all
no emulation specific options.
nios2-elf-gcc -nostdinc -D__linux__ -O2 -I"c:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/c/altera/kits/nios2/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -Wall -c -o mytest2.o mytest2.c
mytest2.c:5:22: iostream.h: no such file or directory
mytest2.c:10: error: `cout&#39; undeclared (first use in this function)
mytest2.c:10: error: (Each undeclared identifier is reported only once
mytest2.c:10: error: for each function it appears in.)
make: *** [mytest2.o] Error 1
make: Target `all&#39; not remade because of errors.
Then I found the file iostream.h but in this directory:
C:\altera\kits\nios2\bin\nios2-gnutools\include\c++\3.4.1\backward
I tried to include this path in the application properties with "Add External Include Path..." but this don&#39;t work either because it sent me the following message of error:
make -k all
mytest2.c:9: warning: return type defaults to `int&#39;
mytest2.c: In function `main&#39;:
somebody has an idea to solve this problem?
Highlighted
Part of your issue, perhaps your whole problem, is that your filename has a .c extension. C++ code should have a .cpp extension, right?
Cheers,
- slacker
