Profiling microC application
I've written a MicroC application that uses iniche stack,
due to performance issues I need to profile it.
I've read AN391 (http://www.altera.com/literature/an/an391.pdf) and was able to use the profiler on a non microC application.
when I've tried to use it on a microC application no gmon.out file was generated.
AN391 state that the 'main' function must return, but 'OsStart' never returns.
Is there a way to profile it?
thanks!
In a regular gcc/gprof environment, you can directly invoke the function that writes the gmon.out. The function is called _mcleanup().
Not sure if it works in NIOS2 gcc environment, but it's worth a shot.
Do you have enough on a indication of CPU load or do you need much more detailed information?
