Given a Cyclone V SoC (HPS) with a EPCS and SD-Card. Is it possible to setup FPGA to load config from EPCS, while booting Linux from the SD Card without reprogramming the FPGA?
Yes.
You may want to have a look at [1]. [1] https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-v/cv_5400a.pdf- Mark as New
The Booting and Configuration Guide touches on independent booting only briefly. I am trying to do this on a Cyclone V SOC device and am not having success.
MSEL, BSEL, CSEL lines are all good but the FPGA does not load if the BSEL is anything but 001. I am trying to load independently with the following set up: MSEL = 10010 BSEL = 011 (NAND FLASH) In this case the preloader and application load but the FPGA does not. In addition, if the BSEL lines are anything but 001, I am unable load the FPGA .sof through JTAG. Any thoughts would be appreciated. Thanks Kevin.
