Program for SD Card
hello
I am a beginner and I need a program to read and write in a SD card
cordially
Hi, Windows can read and write to SD Card ! :-)
Do you mean that you want a board able to read and write to SD Card ?
I think the sd card should be readable by windows, shouldn't it ?
If so, it implies a FAT (File Allocation Table) and a "driver".
Altera tutorials contains examples to read from SD Card.
There is a MP3 touchscreen player built with an Altera dev kit. Find it in this forum.
It is not trivial for a beginner.
Look at opencores.org
Free or opensource SD CARD drivers you can find have poor performance because they use only one data signal while SD CARD has 4 data signals
There are also drivers (Elcamino, ...) that you can pay thousand dollars to do it.
official : http://www.altera.com/products/ip/iup/peripherals/m-elc-sd-mmc-spi.html
http://www.alterawiki.com/wiki/mmc/sd : for experienced users.
