hi, I cann't flash programmer ,I need help!!.
I use Quartus5.1+sp1,NiosIDE5.1+sp1.I use EP2C35 board of altera. 1. In SOPCBuildr,I add nios2 cpu,onchip-memory,jtag uart,epcscontroller. 2.I generate it 3.in Quartus,I update it to Ep2c35.bdf,and comopile. 4.create "hello world" project in NiosIDE,and builder it,there is no err. 5.in NiosIDE,select "tool->Quartus programmer",and load the configure file EP2C35.sof. 6. in NiosIDE,select "hello world" project and run. it work right. 7.in NiosIDE,select "tool->Flash programmer", I check FPGA configure and select hardware image:epcs:U69+0x0 8.press apply and programe flash. the following is the result,I can't solve it for days. I cann't flash programmer with NiosIDE even I add systemID in SOPCBuilder. whether there is something wrong with NiosIDE flash programmer. # ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd D:/EP2C35/software/test/Debug # Creating .flash file for the FPGA configuration $SOPC_KIT_NIOS2/bin/sof2flash --epcs --input=D:/EP2C35/EP2C35.sof --output=EP2C3 5.flash Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=EP2C35 .opt D:/EP2C35/EP2C35.sof EP2C35.pof Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Wed Mar 01 15:40:29 2006 Info: Elapsed time: 00:00:04 Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert EP2C35.pof EP2C35.rpd Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Wed Mar 01 15:40:32 2006 Info: Elapsed time: 00:00:03 # Programming flash with the FPGA configuration $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --cable='USB-Blaster [USB-0]' --epcs --base=0x00000000 EP2C35.flash Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK : Checksumming existing contents 00000000 : Verifying existing contents 00010000 : Verifying existing contents 00020000 : Verifying existing contents 00030000 : Verifying existing contents 00040000 : Verifying existing contents Checksummed/read 296kB in 8.3s Erase not required 00000000 ( 0%): Programming 00010000 ( 0%): Programming 00020000 ( 0%): Programming 00030000 ( 0%): Programming 00040000 ( 0%): Programming Programmed 296KB in 0.0s No change to device contents Leaving target processor paused # Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --epcs --after=EP2C35.flash --input=test.elf --out put=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_lo ader_epcs.srec # Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --cable='USB-Blaster [USB-0]' --epcs --base=0x00000000 epcs_controller.flash Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK : Checksumming existing contents 00040000 : Verifying existing contents Checksummed/read 7kB in 0.1s Erase not required 00040000 ( 0%): Programming Programmed 7KB in 0.0s No change to device contents Leaving target processor pausedLink Copied
