12589 Discussions
Project creation using windows
MHahn4
I'm trying to create a Nios II project in Eclipse, but the New Project-Wizards creates files with Windows style delimiters instead fo Unix ones (the "create-this-app" and "create-this-bsp" files) which results in an execution error:
Executing: wsl ./create-this-bsp --cpu-name Nios2Processor --no-make (C:\some\directory\projectname\software\TestProject_bsp) ./create-this-bsp: line 4: $'\r': command not found ./create-this-bsp: line 11: $'\r': command not found ./create-this-bsp: line 20: syntax error near unexpected token `$'in\r'' ./create-this-bsp: line 20: ` case "$1" in '
I've already set the Eclipse settings to use Unix styled delimiters for new files, but the Wizard still creates the Windows styled ones.
How can I get this running on Windows?
MHahn4
Found out the solution myself: the script uses the wsl command instead of cygwin. Therefore you have to configure a WSL linux and install the dos2unix package and the building tools.
MHahn4
Ahmed_H_Intel1
Thanks Michael for your found. I really appreciate your answer.
