I am new to Cyclone V and VxWorks, I try to run the given sample code vxworks_sampleapp_ed_1.0.
I followed the instructions in AN725_Sample_RTOS_Application.pdf and proceed till page 12 Running the Application. The LED 0 and 1 blinking is working, however when I try the push button FPGA0 and 1 the ISR is not called. I try to disable the ISR and do the polling on the alt_read_word(PUSH_BUTTON_DATA_ADDR); in a while loop. It returns 0x0 no matter the button is pressed or not. Same thing happen for the DIPSW. Anyone face this problem before?Link Copied
Hi i found the problem, the fpga image in my SD is not update to the ghrd_fpga.
after replace the fpga image, it can run as stated. thank you.- Mark as New
you are quite good, found your own missed out steps in about 1 hour!! bravo!
Topic Options
