12603 Discussions
Qsys Pro Software Builder (.sopcinfo does not contain any CPU)
Okay, I'm obviously missing something important.
I'm using Quartus Prime Pro for Arria 10. If I build a system in Qsys (non-Pro), everything seems to work fine. I can take the system through the Software Build Tools and simulation, no problem.
However, if I take the identical project through Qsys Pro, again *mostly* everything seems to work fine.
When I get to the Software Build Tools, I point to the .sopcinfo file and the tools tell me that ".sopcinfo does not contain any CPU". I can see the CPU information in the .sopcinfo file using a text editor.
I suspect that the file format has changed and that there's a new way to build a simulation design for Qsys Pro. Unfortunately, Uncle Google couldn't seem to find it either.
Does anybody have a pointer on how to make this happen? Thanks in advance for any pointers.
Quartus Prime Pro: 16.0.2 Build 222 07/26/2016 SJ Pro Edition
Qsys Pro (Beta) 16.0.2 Build 222
Eclipse: Kepler Service Release 2, Build id: 20140224-0627
Windows 10 Home
Are you using the software build tools from the Pro edition of Quartus? The Non-Pro software tools probably won't generate a system for the Arria 10. If you are using the Pro software tools, it looks like you found a bug in Qsys Pro (Beta). This needs to be reported to Altera.
--- Quote Start ---
--- Quote End ---
Yep, it's all Quartus Prime Pro, Qsys Pro (beta). I have an SR on file on the topic. I'll update the forum with what we find.
Did you click on "Sync All System Info" and regenerate your design again?
TKhan7
Was this issue resolved yet? since I am having the same problem now.
SHauk2
I received the same message while creating a new project. It however, disappeared and was replace with "Project name is empty" within 10 minutes while I was googling the error message. Apparently it was still in the process of parsing the sopcinfo file.
