12596 Discussions
Qsys, System Console, running ethernet loopback issue
I am using Stratix 5 FPGA development kit. I am trying to check ethernet loopback test mentioned in the
"an647_Single-Port Triple-Speed Ethernet_onboardPHY_RefGuide.pdf".Also we have downloaded the required RTL from the Altera website, compiled the design & downloaded the .sof file.
We followed the instructions mentioned in the above document. But when i am configuring the PHY
through config.tcl script, it shows PHY Link down and other messages shown below.
% source config.tcl
Starting TSE MAC Configuration System Console
Info: Opened JTAG Master Service
Info: Configure TSE MAC
TSE MAC Rev = 0x00000d00
TSE MAC write Scratch = 0xaaaaaaaa
TSE MAC read Scratch = 0xaaaaaaaa
Command Config = 0x0000803b
MAC Address 0 = 0x22334450
MAC Address 1 = 0x0000ee11
Frame Length = 0x000005ee
Pause Quanta = 0x0000ffff
RX Section Empty = 0x00001ff0
RX Section Full = 0x00000010
TX Section Empty = 0x00001ff0
TX Section Full = 0x00000010
RX Almost Empty = 0x00000008
RX Almost Full = 0x00000008
TX Almost Empty = 0x00000008
TX Almost Full = 0x00000003
MDIO Address 0 = 0x00000000
MDIO Address 1 = 0x00000000
Regiter Status = 0x00000000
TX IPG Length = 0x0000000c
TX Command Status = 0x00000000
RX Command Status = 0x00000000
Info: Closed JTAG Master Service
Starting Marvell PHY Configuration System Console
Info: Configure On Board Ethernet PHY Chip
Configure PHY.
Set PHY SPEED to 1000Mbps
Enable PHY Auto-Negotiation
Enable PHY In Full Duplex Mode
PHY read Control Register = 0x00001140
PHY read AN Advertisement Register = 0x00000001
Advertise PHY 1000BASE-T Full Duplex
PHY read 1000BASE-T Control Register = 0x00000e00
Set PHY Synchronizing FIFO to maximum
Set PHY HWCFG_MODE for SGMII to Copper Without Clock
PHY read Extended PHY Specific Status Register = 0x00008484
phy link down!
phy speed and duplex resolve failed!
PHY operating in Half Duplex mode.
PHY operating Speed 1000Mbps
Starting TSE PCS Configuration System Console
Info: Configure TSE PCS
TSE PCS rev = 0x00000d00
TSE PCS write scratch = 0x0000aaaa
TSE PCS read scratch = 0x0000aaaa
TSE PCS if_mode = 0x0000000b
TSE PCS control register = 0x00001140
Waiting Link Up.....
Link is established!
Partner Ability:
copper link interface is down.
Copper operating in Half Duplex mode.
Copper operating Speed 10Mbps
Please let me know if i am missing anything in proper configuration.Also find attached the design for your reference.
Please also check from your side and let us know the feedback at the earliest possible time.
Thanks in advance.
