I have a Qsys design on ArriaGX which istantiates a couple of DDR2 SDRAM controllers with ALTMEMPHY. This design has been ported from SOPC Builder Version 10.11 Build 197, where it compiled without problems. Compilation stops with these errors: Error: Following WYSIWYG I/O primitives are not properly connected to top level pins Error: padio port of the bidir WYSIWYG I/O primitive "HSFC_NIOS:U9|HSFC_NIOS_ddr1:ddr1|HSFC_NIOS_ddr1_controller_phy:HSFC_NIOS_ddr1_controller_phy_inst|HSFC_NIOS_ddr1_phy:HSFC_NIOS_ddr1_phy_inst|HSFC_NIOS_ddr1_phy_alt_mem_phy:HSFC_NIOS_ddr1_phy_alt_mem_phy_inst|HSFC_NIOS_ddr1_phy_alt_mem_phy_clk_reset:clk|DDR_CLK_OUT[0].ddr_clk_out_p" is not directly connected to a top-level bidir pin Error: padio port of the bidir WYSIWYG I/O primitive "HSFC_NIOS:U9|HSFC_NIOS_ddr2:ddr2|HSFC_NIOS_ddr2_controller_phy:HSFC_NIOS_ddr2_controller_phy_inst|HSFC_NIOS_ddr2_phy:HSFC_NIOS_ddr2_phy_inst|HSFC_NIOS_ddr2_phy_alt_mem_phy:HSFC_NIOS_ddr2_phy_alt_mem_phy_inst|HSFC_NIOS_ddr2_phy_alt_mem_phy_clk_reset:clk|DDR_CLK_OUT[0].ddr_clk_out_p" is not directly connected to a top-level bidir pin Where HSFC_NIOS is the Qsys project name, while ddr1 and ddr2 are the controllers. Has anyone seen this before? Thanks in advance, SergioLink Copied
I get the same problem with Quartus 11.1 sp2. Did you solve it?
Topic Options
