I just downloaded and installed Quartus Prime Lite Edition on Ubuntu 20.04 LTS. Just about every button I press gives me the error "XPCOMGlueLoad error for file /usr/lib/firefox/libmozsandbox.so:
/home/tom/intelFPGA_lite/21.1/quartus/linux64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /usr/lib/firefox/libmozsandbox.so)
Couldn't load XPCOM."
Any pointers on how to fix?
Thanks in advance.
Hi @tomalogix
Have you try to install libc6:i386, libncurses6:i386, libxtst6:i386, libxft2:i386, libstdc++6:i386, libc6-dev-i386, lib32z1, lib32ncurses5, libbz2-1.0:i386, and libpng12 libraries? As mentioned in the User Guide Table 1. Prerequisites for all Intel FPGA Software below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
I am also experiencing this error on Ubuntu 20.04.3 LTS.
I installed all of the stated prerequisites via this script:
#!/bin/bash
set -x
sudo apt install libc6:i386 libncurses6:i386 libxtst6:i386 libxft2:i386 \
libstdc++6:i386 libc6-dev-i386 lib32z1 libncurses5:i386 \
libbz2-1.0:i386
# libpng12
sudo add-apt-repository ppa:linuxuprising/libpng12
# sudo apt update # (now performed automatically by add-apt-repository)
sudo apt install libpng12-0
but I still get the error when I launch quartus and click on any of the buttons:
$ quartus
/home/user/intelFPGA_lite/21.1/quartus/linux64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /usr/lib/firefox/libmozsandbox.so)
I found an explanation and a solution.
Explanation:
This occurs because Quartus-Lite package includes copies the libstdc++ shared libraries which are older than those provided by the system.
Solution: Ensure that `quartus` uses the system-provided libraries.
Option 1: (Preferred) Use `LD_PRELOAD` to ensure the proper libstdc++ shared library is loaded. Add the `LD_PRELOAD` line (or equivalent) to your shell startup file (e.g. `~/.bashrc`):
# Intel Quartus and friends
export QSYS_ROOTDIR="/home/warnes/intelFPGA_lite/21.1/quartus/sopc_builder/bin"
export PATH=$PATH:$HOME/intelFPGA_lite/21.1/nios2eds/bin:$HOME/intelFPGA_lite/21.1/questa_fse/bin:$HOME/intelFPGA_lite/21.1/quartus/bin
export LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libstdc++.so.6
(I also included the QSYS_ROOTDIR line added by the installer, and adding the quartus tool binaries the path.)
Option 2: (Hack) Rename all of the shared libraries within the install directory to prevent `quartus` from finding them.
cd ~/intelFPGA_lite
find . -name "libstdc++.so*" -print -exec mv \{\} \{\}.orig \;
I tested both on Ubuntu 21.04.3.
