- Email to a Friend
I have installed Quartus II 12.1sp1 on Ubuntu 12.04LTS. I was unable to launch Quartus from the Dash. I found it in the /home/username/altera/12.1sp1/quartus/bin folder. I now have to launch it from the terminal everytime I need to launch it. How can I add it to the Dash? Also, I am unable to launch NIOS II. I tried searching it in the home/username/altera/12.1sp1/nios2eds directory but cannot launch it. Getting the error: ./nios2-ide: 17: exec: /bin/eclipse/nios2-ide: not found How can I launch NIOS II? Thanks.Link Copied
- Email to a Friend
- This forum is about running Linux on Nios II, not running Quartus/Nios tools on Linux.
- You need to run /opt/altera/nios2eds/nios2_command_shell.sh to set up the environment, including your PATH to run nios2 tools.
- nios2-ide was been replaced by eclipse-nios2 about 3 years ago.
Topic Options
