Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Quatrus 4.0 - ok! but 4.1 sp1 is not ok ?!
I have a problem with generating Modelsim project in SOPC
When i use Quatrus 4.0 - Modelsim project is generated ok
But whet i upgrade to Quatrus 4.1 - SOPC start trow error in generation if I set checkbox with generating Modelsim project
Now i turn back to Quatrus 4.0 an all work just fine
So, is someone knowns - in Quatrus 4.2 that bug fixed or not ?
Highlighted
Re: Quatrus 4.0 - ok! but 4.1 sp1 is not ok ?!
I think the problem is resulted from the license of the QII
Highlighted
Hello, AlexS
May be you do not set the path of the ModelSim software in SOPC Builder.
You can do as below:
1. Open SOPC Builder.
2. Choose SOPC Builder Setup > ModelSim Directory (File menu).
3. Browse to the directory "<ModelSim installation directory>/win32aloem" where the ModelSim executables are installed.
4. Click OK.
That&#39;s all.
Bye.
