Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Question about the Avalon Performance Counter
1. alt_get_cpu_freq() is not defined by "altera_avalon_performance_counter.h",
which header file can I use for this function?
2. When I run the program using Nios II instruction set simulator, it gave me a
warning : "SOPC Builder system component performance_counter_0 is not
supported by the simulator. Simulation may be incorrect if your software
attempts to access it". Also I got an error: "Error! Failed memory access in
component cpu_0 - Reading data 0x0 from uninitialized memory (addr =
0x3ff68) Error! : Simulation failed in component cpu_0 at instruction 3257
(PC=0x21e4 instr=0x24000317)." So, which tool except Modelsim can I use to
run the program with performance counter? Actually, Modelsim is very slow if
running a very large code.
Thank you very much!
Highlighted
Re: Question about the Avalon Performance Counter
--- Quote Start ---
    which header file can i use for this function?
--- Quote End ---
are you sure? I have it in the file
components/altera_avalon_performance_counter/HAL/inc/altera_avalon_performance_counter.h
... it's the last function declared!
--- Quote Start ---
2. when i run the program using nios ii instruction set simulator, it gave me a
    warning : "sopc builder system component performance_counter_0 is not
    supported by the simulator. simulation may be incorrect if your software
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12614)
--- quote end ---
--- Quote End ---
I think the simulator only implements a few basic peripherals...
--- Quote Start ---
2. also i got an error: "error!  failed memory access in
    component cpu_0 - reading data 0x0 from uninitialized memory (addr =
    0x3ff68) error! : simulation failed in component cpu_0 at instruction 3257
    (pc=0x21e4 instr=0x24000317)."
--- quote end ---
--- Quote End ---
In the simulator, You cannot read from a location that has not been previously written... that&#39;s typically a bug in the software (unless you want to read some random values...)...
In any case look also at this post:
http://forum.niosforum.com/forum/index.php?showtopic=314&hl= (http://forum.niosforum.com/forum/index.php?showtopic=314&hl=
--- Quote Start ---
so, which tool except modelsim can i use to
    run the program with performance counter? actually, modelsim is very slow if
--- quote end ---
--- Quote End ---
I think you have to use the real hardware 😞
Paolo
Highlighted
Thank you very much, paolo http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
--- Quote Start ---
originally posted by paolo.gai+feb 8 2006, 03:16 am--><div class='quotetop'>quote (paolo.gai @ feb 8 2006, 03:16 am)</div>
--- quote start ---
<!--quotebegin-ruling@Feb 7 2006, 11:55 PM
--- Quote End ---
... it&#39;s the last function declared!
--- Quote Start ---
--- quote end ---
--- Quote End ---
--- Quote Start ---
--- quote end ---
--- Quote End ---
--- Quote Start ---
--- quote end ---
--- Quote End ---
Paolo
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12624)</div>
[/b]
--- Quote End ---
