Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
12453 Discussions
Question concerning Simple Socket Server's SW
Background to the question:
I am using the Terasic's ALTERA DE3 development board (later called main board). This is connected to the
1 Gbps HSMC NET card through the HCTC A-contact on the main board. Everything is working fine via the
channel 1 Ethernet interface and software communicates well on 1 Gbps Ethernet through the Ethernet bus.
However in the documentation of the Simple Socket Serves software is said that software has interrupt support
for the Ethernet circuits (interfaces) on the 1 Gbps HSMC board. I do find the interrupt service routine when
DMA has transfered datta, named tse_sgdmaRx_isr.
Question:
But when I go and open the HW RTL-scheme I do not find any interrupt lines coming from the used Ethernet
circuit (interfaces), through the contact and connected to main board's FPGA and Nios II processor.
How is this solved in software in main card? Is the status of the used Ethernet circuit checked/polled out with
help of some task or via/in the Timer interrupt or via/in the DMA interrupts routines in some way? Or perhaps
there are some treads that polls finds out the status of the Ethernet circuit? Of cause there is some rx bit active
in the Ethernet-circuit that is set but were is this bit checked in sofware finding out that now there are data in
rx buffer of the used Ethernet circuit and now the DMA channel can be started to transfer data to the descriptoir
memory?
Very interested in the answer!
Best Rgds!
