Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Ram 2-port connect to nios
Hello!
I am new in qsys. I need to connect my nios processor with ram 2-port block in fpga in read/write mode. 1 port will have an access from fpga logic, second connects to nios. What kind of bridge i need to use?
The easiest thing to do is just add this from the IP Catalog in Qsys. Connect one port to Nios and export the other port to connect to the rest of your design outside your Qsys system.
