12600 Discussions
Read wait on nios component not working / bus timing problem ?
I have made a Nios/qsys VHDL component.
The component has a read wait of 2 cycles (defined in signals & interfaces in qsys). (See attached JPG)
In the component I implemented for test purposes a shift register and I read the contents of the shift register back with a C program:
if (avalon_slave_byteenable='1') and (avalon_slave_address="0010") and (avalon_slave_read='1') and (RcvRdreq="0000") then RcvRdreq <="1111"; -- fill shift register at read end if; if (RcvRdreq/="0000") then -- shift shift register if not zero and set value on avalon bus: RcvRdreq <='0' & RcvRdreq(3 downto 1); -- shift register avalon_slave_readdata<="0000" & RcvRdreq; -- put value on bus end if; reading value of bus with C program:
while (1) { int status; status =IORD_8DIRECT(COMP _BASE,2); printf("Status = %x\n",status); } The result I get in the nios console window is 0x0F.
If I force the value of rcvRdrReq in the VHDL program, the output changes to the appropriate value, so reading of thebus at the right location works properly.
The fact that i get 0x0F means that the value is read directly after issuing the read request and not after 2 cycles?
I assume oversaw something but I do not see what ? Please comment.
Johi.
Solved,
Value of 0xFF is correct.
Interpretation of timing diagram was the problem.
Johi.
