Reading EPCS
Hello, I am trying to read data in EPCS by the following:
char buf[65535];
alt_flash_fd* epcs = alt_flash_open_dev(EPCS_FLASH_NAME);
alt_epcs_flash_read(epcs, offset, buf, length);
I have tried various offsets & lengths,
but buf is always filled with 0x14141414...
I am booting my board from EPCS without any problem,
so I am sure this is not the right answer.
Am I missing something?
Thanks in advance.
This threat discussion below seems is demotrating the usage of the read and write EPCS as well.
http://www.alteraforum.com/forum/showthread.php?t=18461
Thanks, tony_stark.
I did read the post, but still not working. I tried below:
static flash_region *p_epcs_reg_info;
static int num_epcs_regs;
alt_u8 buf[16];
alt_u8 buf2[16] = {0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F};
int error = alt_epcs_flash_get_info(epcs, &p_epcs_reg_info, &num_epcs_regs);
alt_epcs_flash_erase_block(epcs,0);
alt_epcs_flash_write_block(epcs, 0, 0, (void*)buf2, 16);
alt_epcs_flash_read(epcs, 0, (void*)buf, 16);
As for p_epcs_reg_info & num_epcs_regs, I get below which seems OK:
offset=0, region_size=2097152, number_of_blocks=32, block_size=65536, num_epcs_regs=1
I get error = 0, epcs is not NULL, so there seems to be no error.
But I still get 0x14 for buf[0] to buf[15]..
Is there anything else I should look for?
Thanks in advance.
Did you check whether alt_flash_open_dev() returns a valid handle and if alt_epcs_flash_get_info() returns no error?
Your posted code misses these points
Thanks Cris72,
Yes, I did. As I wrote above,
epcs was not NULL & error = 0
Hello, I found out my problem.
I was not connecting nCS of EPCS properly.
Assigned it to "nCSO" in my top module, but passing "n_CSO" to the lower module.
I wonder why Quartus did not raise an error because "n_CSO" exists nowhere in my code...
It was bit tricky to find out, because configuration works totally fine.
I was not aware that the problem could be on my FPGA side.
--- Quote Start ---
--- Quote End ---
good one! we all also never aware something not right with the FPGa and we focus on the software only :D
