Hi all,
In our project we are coming across this strange issue which is unsolvable, symbol 'capdelaytime_base' could not be resolved qcon_test_prog.c /qcon_test_prog line 3638 semantic errorThis is happening for number of Symbols (part of system.h) which were mostly added in the later part of the design. It is not showing up all the symbols. What i mean to say is there are other symbols from the same file which are showing up correctly. The constant is listed in system.h and system.h has been included in the c file. Build and execution is working correctly. What is this issue ? Any known solution for this ? Thanks Santhosh N
